|  | Home > Technical (L322) > Upper Tailgate |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Don’t think the metal bit is any different, if anything the earlier ones are less prone to rusting..... could be wrong on that though  | ||
|  13th Jul 2020 6:02pm |
| Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132      | Metal and glass is all that I need. Mine has a little rot and prefer to change for a rust free one. Current cars
|  13th Jul 2020 6:04pm |
| Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 22      | I’ve bought one to do the same, on looking I think the glass might need to come out as there is no way I can remove the old loom from the replacement tailgate, & I’d definitely wouldn’t be able to feed my loom back in. But if it’s been done be anyone please comment & help us out. | ||
|  14th Jul 2020 4:45pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Yes the loom can be changed with the glass in sir... Its like playing with a Rubik's cube but yes it can be done  | ||
|  14th Jul 2020 4:57pm |
| Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132      | Perfect.
|  14th Jul 2020 5:02pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Take your tailgate trims off and take your time stripping out everything off your old tailgate while it’s still attached to your car... You should land up with all the wiring exiting through one hole in the top of the tailgate... only then would I unbolt your old one, fit the replacement with all the trims wiring etc still fitted to it! (Remember DONT CLOSE IT!!!) then with it supported on the shockers (or a trusty old sweeping brush) strip out everything, the same as you did with your original! This will allow you to refit everything from your original with confidence 👍
|  14th Jul 2020 6:43pm |
| Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132      | Thanks
|  14th Jul 2020 6:47pm |
 Got my tailgate this morning and the old electrics were simply cut off the donor car, this allowed me to practice stripping out the old electrics. Took mt about 10 minutes to work out how they were installed and how they can come out. The loom is fed into a gap between the glass and the frame allowing one to pull the cables around the edge of the metal frame between the glass and the frame easily. Will install mine tomorrow if I feel the urge, or the rain stays off. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE | ||
|  15th Jul 2020 5:15pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Its much easier when its in front of you isn't it...  | ||
|  15th Jul 2020 8:33pm |
| Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132      | It is much easier when it is in front of you and you are not in the boot looking up and trying to work out how it all goes together.
|  15th Jul 2020 9:06pm |
| Posting Rules
