![]() | Home > Technical (L405) > Dry noise noise under acceleration - Diff problem? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
wheel weight rubbing on brake dust sheild, bent brake dust sheild...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Stan beat me to it... A classic when changing wheels |
Not sure if it’s a wheel weight or brake shield rubbing so haven’t yet jacked car up and rotated the wheels as yet, because:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
As it’s been sat, I would give it a few miles before throwing the panic switch Ryan.🤔
Cheers Mark, it’s off on a long trip soon so getting it ready. We have the breakdown and the warranty cover just in case 🤞😂 |
220 miles in so far and the noise isn’t for shifting. It has now been described as like a brushing sound. It stops at about 75mph. Then at 75 mph the grinding/ brushing sound is replaced by a sort whirring/ low level whistling wind noise that sounds like its coming from underneath the car/drivetrain. The when slowing down to roundabouts and turning corners etc at about 10 to 20 mph it sounds (whilst under acceleration) like that grinding break disc noise. Annoying. |
still think you should take each wheel off and inspect.....i recall back in my days as a tyre centre manager a similar problem and it turned out to be part of a 'stick on' weight flapping about and hitting the disc shield.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Would have thought the weight would have come off by now if it was that.... might be wrong.....
Cheers... do wonder if it indicates “dry joints” type scenario 👍🏻 |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Not trying to be a scare monger BUT does the noise sound like its coming from towards the back and middle of RR ? Mine made a similar noise when diff seal was replaced incorrectly leading to failed rear diff, hopefully not your issue |
Thanks very much Dolph 👍🏻
Hopefully its not that , mine started to make the noise after approximately 2 - 3000 miles after the seal change. It got progressively louder after that. If nothing else its worth ruling it out |
Ours hasn’t even done 2k miles since the seal got change in February. I’ve booked it with the main dealer that did the work but it’ll be next week |
Hopefully its something simple but atleast its under warranty |
