![]() | Home > Technical (L405) > 2014 RRL405 needs coolant every week |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8784 ![]() ![]() ![]() |
Not a common engine in these parts I’m afraid, you may even be the only one on here with one.
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
If there are no visible leaks then it might be the head gasket. A failed head gasket will usually give a white exhaust. ----------
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 64 ![]() ![]() |
A friend had the same issue on his 5.0 sc and it was the water pump, replaced and now fixed. Not very visable signs of a leak but careful inspection showed markings below the pump area. |
DNZFLS007 Member Since: 03 Jul 2020 Location: houston Posts: 2 ![]() ![]() ![]() |
Yes I'm responding 125,000 miles later....the Rover is running good and it was the water pump......no problems since...thank you |
Good to hear. |
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 ![]() ![]() ![]() |
I have a 2014 3.0l since new and now it is drinking water. I have found out that the rear offside (UK car) there is a set of hoses that send coolant to the rear heating system and these have a leak. This is going to set me back £2000 to have the pipes replaced due to the rear sub frame will need to be lowered to gain access.
