![]() | Home > Maintenance & Mods (L322) > No/Minimal Heating |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
When my 322s had heating problems they were cured by replacing the final stage resistor and lubricating the flaps that control where the hot air goes, I didn't do the work so can't offer more than that, sorry. Only Range Rovers since 1988 |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Wot CS Said. Its normally the flaps sticking. Try removing the pollen filter and have a look. Mine worked after I refitted the pollen filter. |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
I've had my 2003 L322 for nearly 5 years and have often complained about the lack of heat into the cabin.
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
I’m sure it was fine before. However, I have only had it on full cold ac for a while now.
Finally found time to look deeper into this today.
Where is this valve? Ron B. VK2OTC
| Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570
Can you add a photo of the valve & where it is in the engine bay. |
All the information I found was for the 3.6 tdv8.
| All times are GMT |
