![]() | Home > Maintenance & Mods (L405) > spares - where can I get this? |
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 ![]() ![]() ![]() |
What model year? The 13-17 PN is LR047409 I believe. |
crikey, if that is the part number they aint cheap... ... - .- -.
MarkinNantwich Member Since: 15 Jul 2020 Location: nantwich Posts: 42 ![]() ![]() ![]() |
Very expensive for a little plastic grill, some in the US at 180usd |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
There are 405 parts available at breakers and / or on ebay
Also this: https://www.google.com/url?sa=t&rct=j&...mDkeh3w0my
The almond PN is LR047413. Also that’s for the LH. The RH might be a different PN. From the picture it looks like it’s just missing the typical metal barb clips. |
Wilpert Member Since: 22 Jun 2020 Location: London Posts: 103 ![]() ![]() ![]() |
thanks,
That’s the thing. The heavy handed fool has broken the clips and they are plastic. Tbh I could do as Stan says and use double sided tape but it won’t pull tight and clip into place and I’m being a bit “new car ish” I just hope the speaker fix isn’t a challenge but if the rest of the system works then it can’t be too serious ..... can it ? |
a wild guess this is (I'm sounding like yoda)
is that just a case of disconnect and reconnect battery and will it mean that I would need to reset everything afterwards?
Do you have access to a diagnostic tool for checking for DTCs? In theory, if there is a disconnect between the amp and the speakers, there should be a DTC logged somewhere. The seat speakers have a dedicated channel on the audio amp. |
its been plugged into a diagnostics tool recently but no fault code re radio or speakers, although i suppose the code could have been cleared?
I was wondering about the under-seat connector....
I must try that |
