Home > Maintenance & Mods (L322) > Reset All Defect Codes
ricky25
United Kingdom 2003 Range Rover Vogue Td6 Rimini Red
I'm trying to do a "Reset all Defect Codes" to get rid of Air Suspension Inactive fault showing. I've worked through the procedure carefully. My car ID is A140141 so the calculated figure is "10". However when I get to the final stage - push right button again I get "Lock 01" through to Lock 40 but not the numbers through to 21 to reset the codes. Can anyone please explain this and help please ?
Post #562047 19th Jul 2020 6:11pm
Brian Considine
If the indicated fault has been caused by battery disconnected/flat issues then you need to run the engine & turn the steering from full lock to full lock a couple of times. 2003 Range Rover Vogue TD6
Post #562053 19th Jul 2020 8:07pm
ricky25
Thank you. I've tried that a few times but it doesn't seem to work for me ! Thus, I was trying to do a fault code reset - which also doesn't seem to work for me !
Post #562060 19th Jul 2020 8:25pm
You can't reset a fault code without fixing the fault, it will just come back..!! Pete
Post #562085 20th Jul 2020 1:11am
ricky25
I think the error code results from a period of low battery voltage which has since been rectified.
Post #562095 20th Jul 2020 10:31am
