Home > Technical (L322) > Battery Light Flashing and then staying on
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
Hi All
I have a battery light that comes on and off when driving but stays on at idle.
Battery is quite new about 1 year old and charges to 12.6v so i think thats fine.
However the alternator seems top be under charging at 11.9v so i have got a reading at 14v when i first tested but now it seems to always be at 11.9v
I'm pretty sure the alternator is fubar but i have heard of bad engine earths, so before i run out and change the alternator what should i check for?
Thanks in advance
Chris
Post #562127 20th Jul 2020 5:25pm
Brian Considine
As a quick comparison test you could see what the readings are using a jump lead from a clean chunk of engine to the battery negative.
If you get higher voltage reading this could point you towards a defective engine earth. 2003 Range Rover Vogue TD6
Post #562133 20th Jul 2020 6:22pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Almost certainly the alternator is on its way out
Get it checked ASAP or you will be stranded and or need a new battery as well as an alternator
Post #562187 20th Jul 2020 11:41pm
Snowy90 L322
Sounds a good idea, 99% certain it is the alternator but worth a check.
Post #562217 21st Jul 2020 9:55am
Snowy90 L322
Thanks the car isnt going anywhere right now so will swap the alternator soon btw its done 155k miles so its done ok! Just strange that it seems to have gone quite quickly rather than slowly dropping voltage?
Also no strange sounds coming from it.
Post #562218 21st Jul 2020 9:57am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Just done this - 168k and it was the carbon brushes that were worn. Changed them myself and all back kicking out 14.1 v again. Initially was the same as yours at 11.5 volts.
Post #562285 21st Jul 2020 9:31pm
Snowy90 L322
I assume thats an alternator out job? Where did you get the brushes?
Post #562992 29th Jul 2020 2:37pm
