Home > Technical (L322) > Access Height Mode
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Access Height Mode
Hi all.
Just read in a post on this forum that a member was advised not to "keep raising and lowering the suspension" as this could result in "premature wear and failure".
Was wondering if that meant one should refrain from engaging access height mode on a regular basis?
Equally, I have been advised to engage access height mode when parking for a period of time (eg. overnight or longer) as this will help prevent failure.
Confused
Any thoughts?
Cheers! -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #56219 23rd Mar 2011 5:13pm
access height is used when coming to a standstill so that driver/passengers can disembark comfortably, if this feature wasn't supposed to be used every time then land rover would have made a comment about not using it to much...
putting the range into access mode overnight would help those little airbags have a rest and therefore prolong their use..some members dont touch the access mode and they havnt had any problems... ... - .- -.
Post #56223 23rd Mar 2011 5:23pm
dan_uk_1984
The pump often runs during a normal drive cycle, so wear on the pump is not an issue here.
The suspension bags move a LOT under normal use, ie speed bumps, pot holes etc. So raising and lowering really wont cause a problem.
Consecutive access to off road adjustments can cause the compressor to overheat, but when it cools down all will be fine.
As per the manual, one should only select access mode whilst moving - ie not whilst stationary.
I believe that if the car is in access mode, it won't do its periodic level check every 6 hours or whatever it is. So if you're leaving it parked up, leave it in access mode.
Every time I change a wheel/tyre I spray the bags liberally with silicone spray as this should stop them cracking
Post #56226 23rd Mar 2011 5:26pm
always meaning to ask this question but keep forgetting...do you spray just the outside or all over dan? ... - .- -.
Post #56227 23rd Mar 2011 5:28pm
dan_uk_1984
Did I miss some sarcasm? (it's been a long day)
You cant spray inside them?
I spray all over the outside of the bag when in off road height so most of the rubber is exposed. I also spray the cone so it works its way into the folds (Edna!?)
Post #56229 23rd Mar 2011 5:32pm
no sarcasm dan..thanks Wink ... - .- -.
Post #56231 23rd Mar 2011 5:38pm
Olders
Many thanks chaps. Thumbs Up
Very helpful and in line with what I thought sounded sensible but appreciate the confirmation.
Silicone spray is a good tip. I will remember that!
Cheers. -----------------------------------------------
Post #56236 23rd Mar 2011 5:52pm
