![]() | Home > Technical (L322) > 2008 3.6 gearbox issue |
| maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58
Hi,
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Agreed, get it serviced by someone who knows these gearboxes... |
| dinger645 Member Since: 07 Jun 2020 Location: lincolnshire Posts: 3
Thanks guys
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
In your instance I would suggest a 'megaflush' where 99% of the oil is flushed out & replaced rather than a 'oil & filter' change which only gets 40%-60% of the fluid out.
| Gunni Member Since: 13 Jan 2018 Location: Dorset Posts: 16
My experience for what its worth
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Nothing has the same specification of the ZF oil no matter what it says on the bottle, the oil will be to the same spec but it will not have the friction modifiers that the ZF oil has..! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
| WB Member Since: 26 May 2016 Location: London Posts: 304
Have a read on the ZF website and give ZF customer support a call. The ZF process is to drain, replace the sump/filter with a new one and fill with ZF oil they do not recommend a megaflush. After all would you change engine oil and leave the dirty filter? Bear in mind the age of your filter... I know there are fans of the the megaflush on here but best to do your research. |
| nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 69
Been there done that - fingers crossed for you.
Update.
| All times are GMT |
