![]() | Home > Maintenance & Mods (L405) > I may have a go myself but not sure what I will need. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
i would move the seat forward or back and see if you can stick your hand around and feel for loose connections..
Wilpert Member Since: 22 Jun 2020 Location: London Posts: 103 ![]() ![]() ![]() |
Tried that, with a head torch on and just couldnt get in there, its that little gap and the amp sits below.
didnt know that..
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
If you undo the 4 bolts that hold the seat in place you should be able to tip the seat back towards the rear seats and get a good look underneath. Undo the front bolts first then move the seat forward and then undo the rear bolts. 2011 TDV8 Vogue SE |
noted thanks,
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 ![]() ![]() ![]() |
That’s an external Torx, or etorx |
Getting to the amp is a bit tricky. One you remove the seat, you will find that you will need to move the carpet. To do that, you need to lift the tread plate. To do that, you will need to remove some trim bits that sit on top of the scuff plate. There is a decent YouTube video from powerfuluk. Be sure to disconnect you battery if you unplug you seat. |
Thinking about your speaker issue a bit more. If these are the only speakers not functioning, I don't think your issue would be the amplifier connection. The amp has 3 (or 4) large multi wire connectors for all the speakers, with that in mind, a lose connector would result in multiple speakers not working, not just the seat speakers.
I know you have probably checked numerous times already, but are you sure there isn't some hidden menu option that might be the issue? Something obtuse like sleeping child mode? |
That’s a great and comprehensive reply.
Is that such a thing? I’m going to go and look. |
When you say 2 speakers aren't working, you mean the left and right seats, correct? Each seat has 3 speakers. It would be hard to imagine both seats failing in the same manner.
Yes both sets of 3 don’t work so no sound from either seat at all. |
