![]() | Home > Technical (L322) > New key not recognised by ignition lock |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
There is a chip in the key that activates the barrel to allow you to turn the key.
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 114 ![]() ![]() ![]() |
Does the key physically open the driver's door?
Fully agree with the above, just to add, if you open the key to remove the battery, you are looking for a small black magnet! The size of a small eraser ✏️ on the back of a pencil... You can pull them out easily enough! Maybe swap it for one in a working key and prove the theory before speaking to Duckworth 👍 OH and BE CAREFUL not to drop said magnet as they are tricky little things! Remove it over a dinner tray is my top tip ![]() |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Thanks guys, that’s clarified things. 2006MY 4.2 SC
