Home > In Car Electronics (L322) > Vogue se problems
Mikeglr
Vogue se problems
Hi all, I’ve just bought 2011 vogue se and I’m having a couple of issues, First with the satnav there is no option to enter a post code, I’ve looked in the boot and I don’t appear to have satnav dvd unit just a small silver unit 🤷‍♂️, also I can’t connect my phone with the Bluetooth, the Bluetooth module is there but my phone doesn’t find it when searching
Any help would be appreciated
Cheers
Post #562542 24th Jul 2020 7:29pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Mike,
Can you take a picture of the screen -- I'm fairly sure you will be able to enter a postcode, as I can on mine Smile
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #562544 24th Jul 2020 7:38pm
Mikeglr
I’ll post one tomorrow, I’m sure I should be able to but I can’t seem to find it
Post #562550 24th Jul 2020 8:18pm
mjdronfield
It uses a hard disk for the sat nav, so no drive / slot for an external disk.
You probably have this info already....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #562552 24th Jul 2020 8:26pm
Mikeglr
I don’t seem to get any info like that, it just asks for coordinates (longitude/latitude) nothing else
Post #562553 24th Jul 2020 8:34pm
Bushy30
Have you got it in off-road mode? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #562555 24th Jul 2020 8:43pm
Mikeglr
That’s a possibility as we was toggling through the settings before I bought it, I’ll check in the morning and post a couple of pictures of my screen
Post #562562 24th Jul 2020 8:59pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #562566 24th Jul 2020 9:48pm
coopss
I had something similar where the postcode option wasn’t there - turns out the country wasn’t set to UK. Changed the country to UK (same screen as the entering the address) and the postcode option appeared 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #562577 24th Jul 2020 11:44pm
Mikeglr
Morning guys, thanks for all your help, turns out it was in off road setting, all sorted now 👍
Post #562588 25th Jul 2020 9:32am
Did you sort out the Bluetooth pairing. There is nothing that can't be fixed with a hammer😜😜
Post #562589 25th Jul 2020 9:39am
Mikeglr
No not yet, not only will the phone not detect it, but also the remote for the RSE is not operating the screen’s either, I’m assuming that it connects using Bluetooth 🤷‍♂️
Post #562591 25th Jul 2020 9:47am
mjdronfield
That’s good then.... as above, just the Bluetooth left?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #562592 25th Jul 2020 9:47am
Have you checked the rear cubby to see if all the connections are good to the BT module? There is nothing that can't be fixed with a hammer😜😜
Post #562594 25th Jul 2020 10:15am
Mikeglr
I’ve had a quick check, taken everything apart and blew in the terminals all seems fine, it’s got six months warranty so I’m hoping they’ll change it if its broken 😬
Post #562595 25th Jul 2020 10:30am
