![]() | Home > Technical (L322) > 2007 key won’t turn |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Update; so although I was doubtful, having removed the top section of the steering column and gained entry to the lock plunger housing, I’ve removed the lock plunger and found it to be moving freely. So I lubed it anyway, and plugged the plunger block connector back in to the circuit board but left the plunger mechanism hanging so I could access it, left the cover off and plugged the steering module back in. Reconnected the battery, and inserted the key into the barrel while manually operations the plunger and............ the key still won’t move.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
my car is a 2007 with dash key hole but bmw key
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
If you hold the key beside the barrel you should hear a click as the car picks up the key. Does this happen on yours? Before you put the key in |
Hi, and thanks for your input. To answer your questions though, I had no warning lights whatsoever, and prior to the failure the car was running perfectly. The battery is less than two years old, is in a good state of charge, and both terminals where tight and secure.
Yep, removing the ignition switch was indeed a workup. So while I could easily buy a replacement and fit it, does anyone know of a bench test it’s possible to do? Also, I’m assuming you can remove the key lock barrel so you can reuse your existing key, and I’m guessing the tine hole next to the key slot is relevant? Anyone know the procedure. Would be a huge help. |
So I’ve got to the bottom of it, the actual steering lock mechanism had jammed internally. Nothing to do with the locking pin not retracting or anything like that, just a simple (and typically rare) mechanical failure that nobody seems to have come across before. A replacement top section of steering column and normal service resumed. Stay tuned for next week’s failure..... |
Nespouls Member Since: 06 May 2017 Location: Terrasson Posts: 24 ![]() ![]() ![]() |
Hi Sam, very interested to read your posts as I’m having a similar problem.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1382 ![]() ![]() |
https://www.google.com/search?q=robthecarg...;ie=UTF-8#
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Nespouls
Hello Stuart,
Unless you buy a column from ebay that's starting to suffer from the same issue |
If you do decide to remove the airbag, use a thin screw driver, when you insert it all the way in push it forwards this will dislodge the connector at one side, repeat for the other side, job done
Hello Sam and dingg1, thank you both for taken the time to respond and to provide such useful information, I really appreciate it.
