Home > Technical (L322) > Alarm sounding
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Alarm sounding
Having read all the threads on Alarms I have tried all the suggestions but my alarm keeps sounding on my 2012 TDV8, it usually goes at 9:00 in the evening and sometimes later. (just to annoy the Neighbours).
I have disconnected the bonnet switch and wd40 all the locks.
In theory the single lock should only set the perimeter alarm but when I check on the dash it says alarm set after single lock.
Disabling this doesn't seem to help as when you reopen the alarm is set gain. I have also vacuumed the roof sensor
Handbook says Alarm should be only triggered by door or boot opening, battery disconnect or Sounder disconnect.
I have rattled all the doors and boot with alarm set and it doesn't trigger and also tried locking with the other key.
I am running out of ideas of what to try
Any suggestions?
Roger L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Sunbeam S7 deluxe (in bits)
Sunbeam S8 (restoring)
Post #563473 3rd Aug 2020 4:47pm
To keep the neighbours happy you could also disconnect the sounder until you figure out the issue.
Taken any garden waste to the tip recently? I used to get escapee spiders/beetle that would set off the interior sensors. .
Post #563474 3rd Aug 2020 4:51pm
Rog21
Where is the sounder, I thought it used the horns, I would like to disable inside sensors to help diagnose problem but cant see how to do it as they always seem to set themselves.
Roger L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #563483 3rd Aug 2020 6:07pm
Should be not far from the bonnet button in the gap between the main firewall and the inner firewall, RHS, near the wing. .
Post #563493 3rd Aug 2020 7:25pm
Rog21
Thanks just waiting for it to go off, as a thought can I disable to internal cabin sensors by taping over vents in roof fitting, or if i unplug then will the car lock okay ?
Rog L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #563503 3rd Aug 2020 8:23pm
Rog21
So no alarm last night, lets see if it lasts.
My Icarsoft seems to have logged a backdoor agar alarm so I had stripped back door and disconnected latch, lots of wd40 and re-assembled. I took ultrasonic sensor off and blew clean
Also rest BCU by touching battery leads together.
Not sure which is any made a difference
Lets see
Rog L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #563546 4th Aug 2020 12:48pm
