Home > Technical (L322) > FBH Pre-Wiring? |
A parts list I can check off would be really handy Matt!
2nd Jun 2017 9:49pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
It would really be helpful if you take a photo of the FBH you have purchased as there are a lot of ancillary parts that attach to the FBH to allow it to function, I can then give you a complete parts list of what you need.
2nd Jun 2017 11:41pm |
You're a star Matt, pic of the FBH below... Bought a pump last night too.
3rd Jun 2017 3:17pm |
Hi mate
3rd Jun 2017 8:21pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Just in the process of collecting parts for this retro fit to my 03 Petrol. I have the Webasto and associated brackets and exhaust, had it running up on the bench OK. I do have a couple of questions though. Reading through Matts guide, a divertor valve is used to run the heatered water purely through the cabin heater. Question is do I really need this, or is it asking a bit much of the heater to warm the engine as well as the cabin. Only asking as the valves appear to be the most expensive part of the install.
18th Apr 2019 7:13am |
leusfx Member Since: 24 Jul 2018 Location: prague Posts: 25 |
Hey Guys
4th Aug 2020 12:56pm |
Joffa Member Since: 27 Mar 2017 Location: Leicestershire Posts: 8 |
Hi Matt I posted in the technical thread asking if anyone had retrofitted a webasto to an L322 & had a parts list. Looks like you may have one! Mine’s a MY11 5.0V8 S/C AB & I’ve already found myself a benzine Webasto. I know the wiring look is in there already, and I think I just need the hoses, switch over valve, fuel lines, mounting brackets, T91. Do you have a list of all the part numbers though? I have a local Indy who’s prepared to give it a go but he doesn’t have time to do all the research. If you ever found a TOPIx on it too, that would be great. Thanks! Jof |
6th Feb 2024 10:45am |
