Home > Maintenance & Mods (L322) > Transmission cooler |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Not happened to me but I hate those connections on those pipes, so to make sure they never pop off I've safety tied them with some light stainless wire, might be worth doing next time you have access |
10th Aug 2020 1:56pm |
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 |
Hi I had the exact same problem as you with the oil cooler pipes popping off after the cooler had been changed. I ended up replacing both cooler lines and then cable tying them on tight to the oil cooler itself to stop it being physically possible for them to pop off again.
11th Aug 2020 12:20am |
tommo10ferrets Member Since: 29 Apr 2020 Location: leicestershire Posts: 56 |
Morning both, thanks for the info, i agree, one positive is the oil being changed, but my main concern is /was is there anything else that could possibly be causing the connection to fail apart from a dodgy hose connector, would hate to change the hoses & it happens again due to something else, that's why i suggested backpressure, it just seems strange that i pushed & pulled on them, didn't move, then the test drive, all ok after checking again, then coming off an hour later, hopefully the new pipes will be here today or tomorrow, get them fitted & see how we go, will let you know what happens.
11th Aug 2020 7:50am |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 33 |
I had to replace the trans cooler pipes, I used genuine ones, they came with a warning "ONLY TO BE USED WITH GENUINE COOLER" (or words to that effect), Did you use genuine parts? or a mix of genuine / non genuine? that may be your problem
11th Aug 2020 10:20am |
Afternoon all, thanks for the input rryorks, the cooler I used was sourced from island4x4, Mahle/Beru, it was the same unit as used by another member who posted a "how to do" very good post it is as well, a new rad was fitted to the car about 4 years ago, I have flushed it twice, but I suppose it could still be blocked never had any cooling problems though, when i fitted the cooler & finished everything else, while the car was running & up to temp i got underneath the car to feel the cooling hoses from rad to trans cooler they were very hot to the touch, I know that's not a very good way of testing but it gave me a good indication that I was getting circulation, the only other way I can think of to get a more accurate reading is to get the delta t measurement across the flow & return hoses on both rad side cooling & trans cooler pipework cooling, if temp is more than 10 degrees difference on either side I think I could possibly say that the rad is blocked, I'll give it a go when the new pipes are fitted & gearbox filled again.
11th Aug 2020 5:33pm |
That's interesting, because it was island 4x4 that I bought the pipes from and who put the note on about only using with a genuine cooler! 2010 3.6 TDV8 |
11th Aug 2020 5:39pm |
Morning rryorks, fitted the new hoses, tried to wire them in place with some 0.8 co2 welding wire, too stiff to get a good fixing on, but will get some softer wire & have another go, had a look at the push fit connector, sure enough the 4 holding clips were no good, didn't seem to be any spring in them, so they must have only just caught the flange & when under pressure popped off, took temp readings of the cooler flow & return pipes, 58 degrees at the inlet/outlet ports, with a 5 degree difference,( although i suspect it wasn't fully up to temp) the temp readings at the gearbox end(where the cooler pipework enters the gear box) using a laser temp reader, was 68degrees & 70 degrees respectively.
15th Aug 2020 10:54am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
You are correct about the bottom 8 rows on the main radiator. It needs changing as it Cannot be flushed.
15th Aug 2020 11:45am |
Evening all, hope everyone keeping well, I still wasn't happy so booked the car in to The Mechanical Workshop to let them put the gear box through its paces & to plug into diagnostic reader, picked the car up next day, they told me that everything was fine, the only fault thrown up was for the fan(can't remember the code at the min) but being a bit paranoid about it now i decided to buy a new rad, t-stat modification kit & a vanos solenoid valve(left bank bit tappety) all the gear came by last Friday, so spent Saturday changing out the rad & done the mod to the t-stat, had to wait until Sunday(yesterday)for the 32mm box spanner to arrive (Amazon) for the solenoid valve, swopped that out, refilled system with fluid. started car, the tappet noise has gone & cooling system seems ok, it was getting a bit late so knocked it on the head until i got home from work tonight, hooked up my icarsoft & drove about 20 miles, everything seems fine, recorded the data, when the car was in motion the coolant temp was about 88degrees, rad temp between 60 & 67 degrees, got home & let it idle for 10mins, the coolant temp went up to 91 degrees, rad temp 71 degrees, no hot smell coming from engine bay now, will check the viscus fan next weekend.
14th Sep 2020 8:14pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 835 |
Just confirming it's the m62 v8 tommo as you changed a vanos solenoid. I recently had similar with gear box slip mine turned out to be the radiator common failure on the m62. As you have done the stat mod I would be tempted to swop out the rad just to be sure the last 6 inches of the rad block up the very part that is meant to cool the oil cooler.
14th Sep 2020 8:36pm |
Evening Gxsr, I've done the radiator Saturday(already done the trans cooler a few weeks ago) also done the gearbox filter & oil change x 3, although the 3 oil changes were accidental as the hoses popped.....twice..lol, also done a fluid change on the transfer box & rear diff, still got to do the front diff, got the oil for it. Thanks for your post, its appreciated.
14th Sep 2020 9:20pm |
Looks like you have it all covered |
14th Sep 2020 9:33pm |
Afternoon all, everything's been fine for the last week or so, that is until today, driving on the A47 to fill up the car, dreaded bong from dash, Trans fail program, car changed down to 4th, wouldn't budge from it, at the next roundabout turned round to go home ( had my icarsoft connected & recording) got home had a look at the log & saved it, reset fault codes & took the car out again (5 or 6 miles) never missed a beat, changed & sounded like it should( was recording this run as well), i'm looking to see if i can upload the data to here, hopefully some one can have a look & see if the parameters look ok, apart from the fault codes that is, looks like a transfer box problem, any thoughts will be very much appreciated. P0720 P1615, doesn't look like i can upload the log, the P1615 code will be because i carried out the T-Stat conversion modification.......I think
27th Sep 2020 5:48pm |
