![]() | Home > Technical (L322) > Anyone know where this is supposed to fit? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Can you advise what the codes on the piece are - 'tis a bit hard to read them in pic.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 553 ![]() ![]() |
Hi Ron,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
It appears to be LR part no LR022713 but where it fits is not entirely clear from a search. John
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
when you remove wheel arch liner looking up is FBH and there is pipe going down, the piece go around pipe and itis held in place with wheel arch liner . 2012 TDV8 Black Edition
Norm Member Since: 25 Jun 2018 Location: Mississauga. Ontario. Posts: 32 ![]() ![]() ![]() |
I saw a post of a similar item somewhere, it was a safety bar to be used when removing the full size spare wheel, there was a strap that bolted to the bodywork behind the spare. When you wanted the spare out you engaged the other end of the strap to the lock recess of the lower tailgate then lower the tailgate, the strap tightens lifting the wheel up. The solid plastic gizmo is then fitted to the lower tailgate preventing it closing. Hope that makes sense, have a look at your spare if the strap is there then that's what it's for. |
Thanks for the reply's guys. I think I've figured this out especially once the part number was cross referenced. I'll take a pic to gauge response on whether this is where it goes, as it's still not clear from the parts catalogues...
** Update **
James23 Member Since: 10 Jul 2024 Location: East Midlands Posts: 13 ![]() ![]() |
Hi Jon
Thanks James, really appreciate the reply. |
Wynno Member Since: 19 Apr 2022 Location: Aylesbury Posts: 14 ![]() ![]() ![]() |
Yep - it defo goes there doesn't it! |
