Home > Maintenance & Mods (L322) > Time for a gearbox flush and other TLC items
Gsxr1250dave
Not been done in my ownership so thought it was time to give the old girl a bit of tlc. I experienced a bit of 1st gear slip last week so bought
1. Correct gearbox oil x20 litres
2. New filter n gasket
3. New radiator
4. Fluids for the diff
I havnt had any over heat messages or anything else the service history shows a new rad and oil cooler in 2017 and gearbox oil all carried out by a specialist company.
With 20 litres of new oil I can do a couple of flushes before fitting the new filter and final oil change of the gearbox.
Did my first drain of the sump and refill all went ok I had a look around in my garage and found a new fuel pump for a freelander an old bike battery and a bit of hose solder a couple of wires to the pump and job done. Only took a few seconds to pump a litre of fresh gearbox oil in one at a time so I could see how much went in compared to what came out.
Will do the same again on thursday after iv done a few miles and again next week with the new filter. Then get the rad and diff oils swopped out.
Post #562289 21st Jul 2020 9:49pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
What gearbox do you have fitted?
Jim
Post #562315 22nd Jul 2020 8:06am
Gsxr1250dave
5HP24 in mine it's the 4.4 petrol so usually a pretty good box. The old oil came out black. As I'm doing a bit of tlc on the old girl it's getting a new rad and I'm gonna flush the oil cooler out and check the oil lines as iv had a mystery oil leak I cant find since iv had the car.
Post #562316 22nd Jul 2020 8:26am
Gsxr1250dave
2nd flush completed today gonna run around in it for a bit before doing the final refill and filter change.
The oil cooler isnt leaking nor are the oil feed pipes to it I'm holding off swooping out the rad at the moment new one sat in the garage.
Post #562448 23rd Jul 2020 8:50pm
Gsxr1250dave
Completed my 3rd and final flush plus filter change today. Gearbox silky smooth. I improved on my previous method of refilling by using a 10 litre garden spray bottle connected to my electric pump.
Job done just the diff left as I did the transfer box last week.
Post #565101 20th Aug 2020 10:46pm
jim4244
There is something very satisfying about changing all the various fluids on a Rangie 👍
Jim
Post #565109 21st Aug 2020 8:44am
DrRob
Jim - you're right. I got a buzz around doing my oil and filter change on the 4.4 using my 10L vacuum suction pump. Very clean and easy to do. Highly recommend it over dropping it out of the sump.
I left Bodsy to Megaflush my 8 speed though - with his fancy machine Bow down
Need to change my PAS fluid - think of just decanting out of the tank and topping up with new. Then repeat. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565110 21st Aug 2020 9:31am
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
PAS fluid change
There's a good South Main Auto video Eric O posted recently where he did a 100k service on a Mazda 6. He just sucked out the PAS fluid from the reservoir, actuated the steering and repeated until the fluid looked clear - see from 13:40 in this video:
I've learned so much by watching his videos, he's a great mechanic and teacher. Ditto Jim White at White Details.
fanders Thumbs Up ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #565113 21st Aug 2020 10:39am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
DO NOT touch those plastic clips that hold the pipes on the cooler. After 3 days outside the factory, they turn to glass and disintergrate when so much as looked at. You then need the whole bloody pipe as clips are not available separately . Ask me how I know......
Post #565114 21st Aug 2020 11:00am
Gsxr1250dave
I have no intention of touching them.once I found out there not the cause of my oil leak. I even bought the propr bmw removal.tool just incase.
My leak is higher up on the front just cant find it !!!!!
Post #565124 21st Aug 2020 2:52pm
Gsxr1250dave
Both diffs done today 1 litre of milky old diff oil from the rear and 750 mils of clear but dark oil from the front. Used my electric pump to refill both.
Job done.
Will get back to my head liner soon at some point. Gonna drop some new discs on and an outer cv gaiter as I found a split one.
Post #565863 29th Aug 2020 5:44pm
Gsxr1250dave
Wow almost 5 years ago the cars still going well I'm about todo the same on my 5.0 s/c regarding gearbox service to see if it cures a slight shudder and revs bouncing about 100rpm.
20 litres of fluid sitting here for the initial flush then filter and fluid on final fill. Fingers 🤞.
Bridge seal and tubes sitting here if needed and been following and reading David excellent 5.0 sc write up.
Post #711484 10th Feb 2025 5:46am
