![]() | Home > Technical (L322) > L322 expansion bottle failure? |
| 24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 166
I've got a little bit of a problem with the coolant in my bmw powered v8 (2003)
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
Did not know there was a relief valve, that's what the pressure release cap is there for. The V8`s run higher pressure than the TD6 and are well known for expansion tank failure. Buy a new tank and a diesel pressure cap with number 140 on it as opposed to 200. Hopefully, there is no other problem apart from a split tank. The only other place it can leak is from a water connection or the air bleed screw 2007 TDV8 VSE
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
I’d be looking at the radiator, they are well known for sludge in the lower galleries causing what looks like pressure building up.
Thankyou for the replies.
| Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130
You sure it shouldn't be blanked?
Thanks Spud - now that is interesting.
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
I've had a few britpart parts and find them unfit for purpose. |
PCF000033 2006 4.2 SC |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626
Spot on
