Home > Technical (L322) > Rust
Page 1 of 3 123>
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Rust
After finding levels of rust that I thought did not happen to cars post about 2000, I have found rust on my car which I think is totally unacceptable for the year. Something I have mentioned before, but after spending many hours reading the workshop manual during lockdown I found the following.....
All steel panels are double zinc coated.
During production, vehicle bodies are treated with the following anti-corrosion materials:
Anti-Corrosion Materials
A heat cured, Polyvinyl Chloride (PVC) based sealant is applied to specific joint seams during factory assembly
A PVC based underbody sealer is sprayed onto the underside of the main floor pan and rocker panels, the exterior of the spare wheel well and the forward face of the lower dash crossbeam
An application of cavity wax is sprayed into various body sections
If this is all true then we should not have any corrosion issues, I'm not sure what to say but I can see no signs of zinc coating or any signs of cavity wax any where on my car. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #565052 20th Aug 2020 2:16am
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
There was clear evidence of cavity wax having been applied to my 4.2SC when I inspected/rust treated the sills and rear arches last winter, but I can't say for sure that the wax residues I found were factory-applied or had been done after build.
Dribble of cavity wax on one of the sill holes (these get plugged by a plastic plug):
Borescope view inside the left sill showing wax coating (light brown area, blue stuff is paste adhesive):
Needless to say all areas on mine, inside the sill and outside on the sills/rear arches got a healthy douche of cavity wax and grease, and will be inspected annually during winter maintenance.
fanders ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #565062 20th Aug 2020 9:36am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
The rear arches on the L322 are crap and everyone I have owned or seen has had bubbling near the join to the bumper and bubbling around the arches! The inner door arch also suffers and so does the lower cill. I have had mine treated waxed etc etc etc but I now have an issue again on a car this was immaculate with now rear arch present. these cars are crap supposed to be 4X4 off road worthy well the body panel are worthless if they can withstand the UK weather. Also the boots leak and so do the rear quarters frying all your electrics just for good measure happened to me also!! NEVER BUYING THIS MODEL THE L322 AGAIN I WILL BE GOING BACK TO THE SPORT.... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #565454 25th Aug 2020 3:34pm
dingg1
Go on adios Laughing
Post #565455 25th Aug 2020 3:37pm
another happy customer Thumbs Up ... - .- -.
Post #565456 25th Aug 2020 3:46pm
jaysta10k
😂😂 All we ask for us something that doesn’t rust and fill up with water!! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #565457 25th Aug 2020 3:50pm
mjdronfield
It’s such a shame. Worst thing about ownership. I’ve not seen X5’s or Sports with rust outside....
Or even Discovery 2’s..... 3’s...... 4’s.....
Rolling Eyes 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #565460 25th Aug 2020 4:22pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Not sure why, if you were so disappointed with a car and it's quality you would buy more of the same
And why stick with a brand you say produce poor quality products?
"The rear arches on the L322 are crap and everyone I have owned or seen has had bubbling near the join to the bumper and bubbling around the arches! The inner door arch also suffers and so does the lower cill. I have had mine treated waxed etc etc etc but I now have an issue again on a car this was immaculate with now rear arch present. these cars are crap supposed to be 4X4 off road worthy well the body panel are worthless if they can withstand the UK weather. Also the boots leak and so do the rear quarters frying all your electrics just for good measure happened to me also!! NEVER BUYING THIS MODEL THE L322 AGAIN I WILL BE GOING BACK TO THE SPORT...." 2011 TDV8 Vogue SE
Post #565524 26th Aug 2020 8:24am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
It’s all just a small part of the rollercoaster ride that is owning and running a Land Rover / Range Rover vehicle....😂
Jim
Post #565530 26th Aug 2020 10:42am
not all FF's rust, i had a TD6, 4.2 SC, and a 4.4 TDV8 westie and none of those had rust problems.. ... - .- -.
Post #565536 26th Aug 2020 10:57am
Neither do (real e.g. not Ford) Volvos Wink Thumbs Up .
Post #565546 26th Aug 2020 12:36pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Agreed. My 1998 V70R is rust free however I do remember my Dad having a 240GLT with rust issues.
I also have a 4.2SC with rusty rear arches! Is there a write up anywhere where someone has cut out the rust and welded in new steel?
Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #565547 26th Aug 2020 12:45pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
My L322 was awful compared to my much older Touareg. Land Rover design and build quality is shockingly bad for a car of this market position. The front subframe had extensive corrosion (I dealt with it but it was not good), all fastenings around the car were rusty, brake pipes corroded through.
For very little money the misc fastenings around can be stainless, brake pipes use kunifer 10 which doesnt corrode. A little more thought and appropriate protection the corrosion issues could be overcome, surely galvanising could be done as done by many competitors.
Theres no excuse for Land Rover for a vehicle at this price point. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #565548 26th Aug 2020 1:02pm
dennij
I have to agree with the idea of galvanising a car that sits in the market place that it does. Audi & Porsche used to do this as standard. From what I've seen it's a simple dip treatment so could easily be added to the current process. 2011 TDV8 Vogue SE
Post #565562 26th Aug 2020 2:57pm
AJGalaxy2012
And they really must make serious profit at the prices demanded for Range Rovers, not exactly short of financial headroom. BMW i3 Electric Car
Post #565582 26th Aug 2020 5:20pm
Page 1 of 3 123>
