Home > Maintenance & Mods (L322) > They say it happens with age......
mjdronfield
I went out 5 days ago and could smell a slight bit of sweet antifreeze when I put the car away. Wandered out and thought I’d see if coolant needed top up yesterday. Not unduly low.... put a bit in... spilled a little...
Went out this morning....
I recon that’s from when I smelled it, as the coolant doesn’t seem fresh.
Will keep an eye on it, but suspect I will be laid under it soon 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #565675 27th Aug 2020 3:08pm
mjdronfield
So is the best way to inspect to drive on ramps and remove under tray ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #565689 27th Aug 2020 5:03pm
SS.Lyria
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Loire Blue
On my old D3, off road height with a door left open to stop self levelling was enough room to remove the under tray and inspect. It wasn’t the easiest working position but I didn’t trust those ramps.
Unless of course you mean a proper 4 post ramp which would make the task a whole lot easier.
As said that was a D3 not a FF. My diy days are few and far between these days so I’m assuming a similar clearance on a FF.
Post #565696 27th Aug 2020 6:29pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
When I did my SC I just put it into off road height, a couple of axle stands and there is loads of room to get under.
If you are lucky it will be the same as mine just a new drain plug. I tried changing the O rings but couldn't find the right size.
I also found that all the clips and screws were badly rusted for the under radiator cover, so I replaced with stainless clips and screws.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #565697 27th Aug 2020 6:43pm
mjdronfield
I’m hoping it’s not water pump. Not keen on it being radiator, but that said... it’s probably the original one and getting ready.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #565701 27th Aug 2020 7:01pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I normally put mine into extended height mode which gives plenty of room to remove the under tray and work on most components under the vehicle.
Jim
Post #565739 28th Aug 2020 6:58am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Access is fairly easy, I always put axle stands and I don't trust the suspension going back to access mode.
That coolant is looking way old.. doesn't look like its ever changed.. should be pink in color. You will be guessing what it is at the moment so get under it to see exactly what it is.. doubt it would be the water pump but hey.. could be anything. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #565741 28th Aug 2020 8:02am
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
thought my coolant was old looked like that
but the genuine coolant is orange in colour
so looks like old water and rust that came out of old pintos in the 70s
Post #565742 28th Aug 2020 8:06am
