|  | Home > Maintenance & Mods (L322) > Battery drain after the rain |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | How old is the battery? Have you had it tested? | ||
|  28th Aug 2020 7:22pm |
| Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73      | Battery is good. It might be a year old 2 max. Also alternator is 13.75 with the engine at idle...
|  28th Aug 2020 7:27pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Neither do I.   | ||
|  28th Aug 2020 8:55pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881    | the most common water ingress is into the rear nearside cubby...i'd take a look in there.. ... - .- -.
|  28th Aug 2020 8:58pm |
| Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73      | It won't start again this morning. Have hooked up a battery reconditioner. I have been doing a huge amount of short journeys as we are moving house.
|  29th Aug 2020 8:41am |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | If you get the chance, charge the battery up and then disconnect the earth connection and leave it overnight. Then see what voltage is on the car in the morning. | ||
|  29th Aug 2020 8:43am |
| Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73      | To rule out if the issue is the battery? | ||
|  29th Aug 2020 8:46am |
|  29th Aug 2020 9:03am |
| Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73      | I gave up bought a new battery and threw that in
|  29th Aug 2020 12:16pm |
| gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163      | I had something similar. Water was building up in the spare wheel well. When it got high, it caused the suspension air compressor to short out, training the battery.
|  29th Aug 2020 2:03pm |
| JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61      | Also worth a look at the headlight wipers, if they are not parking correctly they will hold the BCM on causing a drain.
|  6th Sep 2020 12:44pm |
| Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73      | Headlight wipers are all good. A new battery seems to have me sorted for the moment | ||
|  6th Sep 2020 1:35pm |
| Posting Rules
