Home > Technical (L322) > Rust
Page 2 of 3 <123>
mark towill
Canada 2008 Range Rover HSE 4.4 V8 Stornoway Grey
I have a 2008 HSE I purchased during the start of the pandemic. here in Canada. Thought it was reality rust-free until I took it to a body shop familiar with RR. Alias rust lurking under the bottom plastic cladding at the start of the wheel arches. I spent the next week cleaning the steel wire brushing and sanding. Fortunately, the rust had not reached the jacking points.I used a system for hopefully stopping the rust it is called POR-15. It is 3 steps- 1st degreaser cleaner-2nd etching with acid- 3rd the magic hydroscopic paint then Fiberglas painted and put over small rust out holes. I hope to report next year my be loved Harriot rover is not rusting Smile
Post #565614 27th Aug 2020 4:27am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Today I removed the plastic sill protector and the wheel arch liner. By the time the wire brush had done its job, holes in the bottom of the rear drivers side passenger door arch and one underneath which was originally the small hole that the small plastic lug goes in to secure the sill cover !
Copious amunts of rust treatment now on the cleaned off metal surfaces and tomorrow the welding and filling begins. 13 years old and in this state. LR hang your heads in shame.
Post #565690 27th Aug 2020 5:49pm
mark towill
These photos are very reminiscent of my RR. both sides I am sure. The good news is we caught it before it got to the jack sites! Your repair is much more substantial. then my patch. When I first discovered the rust I was going to do the patch and then leave the moisture holding plastic cladding off, but my wife thought otherwise. I will just unclip the cladding enough to rinse the road salts off. Have you thought of waxol both rear quarters ? On your side of the Atlantic, a gentleman did it to a 125000 sterling Westminster. I did it to mine with the POR-15 since both wheels off made easy access. The gentleman`s Westminster did not have one additional screw at the top of the arch to hold the plastic wheel liner in place.
Post #565708 27th Aug 2020 8:20pm
DaveK
Will be waxoyling every orifice before putting sill cover back. Luckily the place where the jacking pad fits was rock solid.
Post #565710 27th Aug 2020 8:29pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Plenty of more information on rusty arches here:
https://www.fullfatrr.com/forum/topic54121.html
fanders ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #565711 27th Aug 2020 8:34pm
mark towill
I am so fortunate to have found FFRR, of course, my terminology is a bit off but we are on the seem page Very Happy
Post #565722 27th Aug 2020 9:30pm
DaveK
Holes welded, vast amounts of waxoyl applied inside and out
side of sill following paint. Black plastic sill trim back on but struggling to get the black plastic clips that go on the underside of the sill to keep it in place ( not the white clips that push in to the sill along the side.)
Post #565860 29th Aug 2020 5:14pm
Classic888
Try ANR2224, used on most of the LR models over many years to fit plastic trims.
Post #565865 29th Aug 2020 5:55pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Nice job.
Post #565870 29th Aug 2020 8:59pm
Xray charlie
England 2003 Range Rover Vogue 4.4 V8 Giverny Green
This was the extent of rot on my 2093 car, both sides and rotten boot floor, I’ve decided it’s too much work so sadly scrapping it 😞😞😞
Post #565881 30th Aug 2020 8:22am
darrenm
I have recently checked my 2010 inc taking out rear wheel arch liners and plastic sill cover and not a single spot of rust
Post #565886 30th Aug 2020 9:47am
DaveK
For so many of them to have suffered this problem in exactly the same place surely means there has been a fault in the production process ?
Post #565950 31st Aug 2020 10:03am
DaveK
Thanks. Have sent off for some. I'm thinking of holding an exhibition next month of plastic fastners that I have bought for land rover products that were completely wrong !! Should take around an hour to view !
Post #565951 31st Aug 2020 10:05am
Johnniehec
Just about to embark on repairing my 2004. I have a couple of questions I would assume if enough pressure was applied here a hole would result, can anyone comment if this would be a UK mot fail?
I see the part number for the black clips for the underside of the sill trim in this post, does anyone know the part number for the white two part clip for the upper edge?
My second photo shows the cavity was applied to the rear half of the near side arch, I can only assume the lower front of the arch where it joins the sill received the same generous amount πŸ€”πŸ˜Ÿ
Post #565973 31st Aug 2020 1:44pm
Classic888
White clips are EYC000310 or may supercede to DYC500080.
Post #565975 31st Aug 2020 2:17pm
Page 2 of 3 <123>
