Home > Technical (L322) > Knee capped. Steering column
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Just got in from a night shift and the FFRR tried to knee cap me when I parked up.
Just stripped it down and the tilt motor has failed. Looks like the worm gear has eaten its self.
Part number QME500070 . On the side of the motor is 0390201703 just thought I'd make reference as that number couldn't be found on a google trawl but hopefully others searching fullfatrr.com will find this and be able to find the correct part number.
The motor appears to work when not on the shaft but a test with a paor of mole grips and the shaft held by hand shows the worm gears are clearly slipping.
Oddly just rang the local dealer - £162 plus vare and tare. Thats actually cheaper than any sites I've found on tinternet. Have to wait till Tuesday mind...
Once the motor is removed I can actually adjust the column tilt by using a 13mm ratchet spanner Thumbs Up
Never rains but it pours!
Will add some photos later chaps - Off to bed - been a long night! 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #56590 25th Mar 2011 10:02am
theres this one on ebay for £144
http://cgi.ebay.co.uk/QME500070-Range-Rove...2a0ed3f0ed
or this bloke wants an offer for two used ones
http://cgi.ebay.co.uk/QME500070-Range-Rove...4aa9c9532b
might be able to do a deal and get them sooner, providing you can cancel your order.. ... - .- -.
Post #56593 25th Mar 2011 10:13am
elpeede
Cheers Stan. I spotted both.. but highly suspect of the two together sold as untested by someone with no prior feedback. The other also sort of left me wondering.. the one I have taken off will still turn until its under load then its stalls but you still here the motor whirring. Decided to play it safe on this item Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #56654 25th Mar 2011 3:00pm
suppose your right, if it goes wrong then LR will replace it... ... - .- -.
Post #56655 25th Mar 2011 3:03pm
