Home > Technical (L322) > Rust
Page 3 of 3 <123
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Here's our 2009 with the plastic sill cover removed. About what I expected to be honest. Will be getting a quote from the local spray shop to repair... N/S as shown is the worst of it. Rust never sleeps.... Shocked Laughing
Post #565983 31st Aug 2020 4:43pm
Bloke
Came over all tight and decided to have a go myself. Sill was filled with waxoyl. Zinc primer for now, top coat to follow. Thumbs Up
Post #566076 1st Sep 2020 6:51pm
Just an aside to all these problems with rust forming at the rear of the cills behind the covers.
Having had the cill covers off last year and luckily found no rust what I did find was a lot of wet dirt. To me it seems water and dirt is getting through the joint between the rear return of the plastic cill cover and the wheel arch liner and draining down to the bottom of the cill cover where it sits and causes corrosion.
To overcome this I cleaned up the rear return of the cill cover and the wheel arch liner and taped up the joint with black Gorilla tape. Once applied you can't see it and after over a year it is still in place.
Might be worth considering. Thumbs Up
Post #566077 1st Sep 2020 7:18pm
Bloke
That's a top tip fella. Will give it a go. Thanks. Perfect night for spray painting here, zero wind, so just been out and flashed over the primer with top coat, just before bad light stops play....
Post #566083 1st Sep 2020 7:55pm
mark towill
Canada 2008 Range Rover HSE 4.4 V8 Stornoway Grey
I think I will try the Gorilla tape tip. I have gotten quite good at removing the plastic sills, however not so good at lining up those clips and retrieving them when they fall in the sill Shocked
Post #566090 2nd Sep 2020 3:54am
Bloke
Ordered a pair of Freelander 2 wheel arch protectors as suggested somewhere on here, thanks.
https://rimmerbros.com/Item--i-LR001624
Post #566105 2nd Sep 2020 12:25pm
Bloke
Cill is looking much better. Glad I got some top coat on last night as rain stops play today....
Post #566107 2nd Sep 2020 12:36pm
MikeO
Now you're just showing me up! Can I buy it back? Laughing
Nice job - looks really great. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #566218 3rd Sep 2020 7:11pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
Had my long waited appointment at a local blasting shop. They did cleaning of the rust at the whole
underbody. Next stop is welding and then the paint shop! Car is 2006.
Post #566226 3rd Sep 2020 8:09pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
WOW Shocked That is some protection job Thumbs Up
Post #566228 3rd Sep 2020 8:55pm
Page 3 of 3 <123
