Home > Maintenance & Mods (L405) > Connecting a battery charger
FFRR64Royal
United Kingdom 2015 Range Rover Vogue SE SDV8 Firenze Red
Hi guys,
I want to connect my CTEK MXS 5.0 Fully Automatic Battery Charger to our Vogue SE, but given the battery nightmare stories I have read on the forum, I thought to just ask the question....is it okay to do so like I have on all our other cars in the past.
I usually hardwire in the standard CTEK quick connection then once a month plug the charger in and optimise the battery.
Cheers.
Post #566086 1st Sep 2020 9:54pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Not a problem, just connect it to the positive and negative post under the hood and you are good to go.
I charge mine up every four weeks as I do a lot of shot trips.
Post #566088 2nd Sep 2020 12:41am
DrRob
I thought it was good practice to use an earth point on chassis and not direct to the -ve post? I'm sure I've read that on here a few times ??? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #566092 2nd Sep 2020 7:36am
The workshop manual says the posts under the bonnet.
I’ve hardwired a CTEK connector to mine - https://www.fullfatrr.com/forum/topic48040...p;start=15
DrRob - the negative terminals thing is best practice for the final connection when connecting straight to a battery - the logic is that a dodgy battery may be leaking and giving off gas. The very last connection, which should be negative to the car with the duff battery, may spark - so it’s safer to use an earth point. Clearly doesn’t apply when using the under bonnet posts - the negative one is effectively a chassis earth point anyway Thumbs Up
Post #566093 2nd Sep 2020 7:46am
DrRob
Cool. I use my 13pin towing electrics to charge battery via a ctek adaptor off the forum shop Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #566094 2nd Sep 2020 8:16am
Phil.
I’ve connected mine directly to the battery under the spare wheel for years and with several FF’s without any issue. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #566099 2nd Sep 2020 10:35am
charlie croker mk2
A Ctek 5 amp charger will have to work hard , the 10 amp would be better . Even the 10 amp has to left for 48 hours before it shows fully charged .
Post #566103 2nd Sep 2020 11:24am
CS
Like Dr Rob I bought an adaptor from the forum shop and charged through the towing electrics, all fine and easy to do. Only Range Rovers since 1988
Post #566114 2nd Sep 2020 3:05pm
Unfortunately with He deployable tow ball, the electrics are not accessible when it’s stowed.
Post #566116 2nd Sep 2020 3:12pm
FFRR64Royal
DrRob, are these still available?
Post #566125 2nd Sep 2020 6:28pm
FFRR64Royal
Might need to invest in a new one....had my original one for a few years now and has been perfect for our normal car batteries
Post #566126 2nd Sep 2020 6:31pm
FFRR64Royal
Just seen the Shop advert Thumbs Up
Post #566127 2nd Sep 2020 6:37pm
My 5 has been fine - but I only ever really use it as a maintenance charger and not to revive a dead battery.
Post #566128 2nd Sep 2020 7:12pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Recently bought one of these. For the cost, £38. I'm very happy with it. Will recharge batteries of everything from motorbikes, cars and 4x4s. https://www.ringautomotive.com/en/product/RSC806
Post #566185 3rd Sep 2020 3:35pm
FFRR64Royal
Chaps, has anyone come up with a genius solution to attaching the CTEK connector to the remote battery posts?
Post #566282 4th Sep 2020 3:21pm
