![]() | Home > Technical (L322) > Leak from above the front diff |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2263 ![]() ![]() ![]() |
Rear output seal which is higher up on the diff? Have you cleaned it up with brake cleaner topped it up and gone for a short drive to see if you can source it that way ? Current stable:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
if not the diff itself, the secondary turbo sits above the diff
coopss any update on this?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I had 2 oil leaks around that area:
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
It’s not using any oil at all and there is nothing on the floor after sitting for a few days.. it’s also had both new turbos.
