Home > Technical (L322) > TD6 Slow to engage drive in the morning
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
Soooo.......after reading this archive thread from 2011
https://www.fullfatrr.com/forum/topic7271-15.html
I am and have been experiencing the same thing since ive had my FF. If car been left sat for more than 6/8 hours it will sometimes take 10 secs, others over 40 second to engage drive. All the rest are fine, sometimes I forget and im sat in the middle of the road lol
The gearbox was swapped for a recon’d box at 110.000, its now on 185.000
At 184.000 I performed an extended drain (left overnight with the pan off). Wasnt a pretty colour - but no Censored in the sump
Had 7 litres drain out total, so 7 litres went back in again with lucas stop slip additive, a specialist in liverpool that deals with the GM & ZF boxes for these Range Rovers and X5s said that they usually recommend if uses for towing/to prolong the life)
Still no difference though experince the same issue where drive takes time to engage so I then greased up the linkage after reading this wiki post, I had the car in the air (door open!) and my neighbour selected through the shifter locations whilst i wd40’d the linkage and cable, then used multipurpose grease afterwards.
http://www.fullfatrr.com/wiki/TDV8_Gearbox...s_of_drive
I actually got better, still took some time but it was usually a few shifts from P to D and we were off.
I guess as its simply just returned to not behaving all the time - I can now only assume that the fluid being cold is a factor and its something else in the gearbox that isnt best pleased ?
Post #566414 6th Sep 2020 9:18am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
That Lucas stuff is incredibly thick and only increases the viscosity of the existing fluid, check out the lab tests on youtube. I would presume that would slow the flow down at cold temps. Are you using dex 3 or full synthetic fluid? When you changed the filter did you get the old seals out, they can be really stubborn and tight. Also, did you use the correct filter, there are 2 types for the GM Box, the correct one has the pickup 1cm lower than the other. When I did my 1st fluid and filter change 50000km after a rebuild I found it had the wrong filter, see the attached photos, the correct one has the black bar which lowers the pick-up
This one is wrong
This one is correct
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #566471 7th Sep 2020 2:03am
mazza7282
Dexron III.....that stuff went out in the stone ages, no im not using that.
Yes that lucas stop slip was very thick, i added a 200ml at a every 800ml of ATF I put in.
I used the well documented process that is on this forum and RAVE.
The filter i’ve got is the pancake one, in your last picture and yup the filter seal did get stuck, so i fished it out with a hook
Im using the Comma ATF fluid that shows approved type on their web site, its synthetic, this is also what was recommended on their system at the motor factors.
I ran this by the ZF and GM box specliast for L332/X5 in Liverpool and they said they put in the euro car parts ATF plus and dont have any problems with it. They also mentioned that Comma stuff I was using would be fine.
The problem i’m having, existed prior to me performing a fluid change anyway, plus drives fine regardless.
I’ve wd40’d and greased up the linkages/selector again for now
Post #566583 8th Sep 2020 8:25am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
If you have a GM gearbox then this is what it was designed to have inside it
If I was in your position I would buy a 20L drum from our onsite oil sponsor and do a triple flush. Then I would top it up and add a tube of Dr Tranny.
Jim
Post #566613 8th Sep 2020 1:57pm
mazza7282
Just a quick update on this one, After greasing & using WD40 on the selector each month.
The car does engage D after about 2 seconds from stone cold, I think that's reasonable enough Very Happy Current Fleet
FF L322 2.9TD6 SE
BMW e46 330ci Msport
Skoda Superb TDI Mk2, stage 1
Audi A3 8P 2.0 T 4x4, stage 2
Yamaha R6 13S
Triumph Thruxton R
Sold, but not forgotten
WJ Jeep Grand Cherokee V8
Post #578564 5th Jan 2021 7:49pm
