![]() | Home > Technical (L322) > Front Struts Conundrum! |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
Are they different manufacturers? Paul,
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
aftermarket or OE? ... - .- -.
| Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233
Well every day is a school day! Both stated as OE but bought from different suppliers, so likely to be different manufacturers!! My error. Another interesting fact is that the pressure required to push the dampers down is different also. Thanks for your replies, lesson learnt. |
| Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 77
Chinese Garbage by any chance?
Unable to confirm country of origin as both supplied in plain box and no markings on units. Adverts stated OEM with 2 years warranty and from a UK based company. |
Sounds fishy...
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
not sure the bag length is a problem because the pump will add air untill the height sensor says 'enough'.
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1056
Why did you replace the drive shaft and carrier bearing?? |
The "old" ones I refer to are the units that were fitted three months ago. Having had the vehicle for over 5 years and driven many hundreds of FFs (worked for LR) after the "old" ones were fitted the front of the car seemed to bounce as if there was no rebound damping from the shock absorbers. So after the most recent work, it is now back to what I think it should drive like.
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
You have a supercharged. Dont they have different shocks on the front from the normal ones ...
| lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513
The SC ones are different as the engine is over 100kg lighter than the diesel. |
| All times are GMT |
