Home > For Sale & Wanted > SOLD. Genuine Land Rover L322 Roof bars
Spr1ngbok
I have 2 virtually brand new roof bars that I bought from Land Rover when I had the L322. Used a couple of times to carry surfboards. I only kept the Rangie a few months then sold it and forgot I had them. Note these are the cross bars, not the longitudinal rails
Looking for £250
Post #566267 4th Sep 2020 12:19pm
Spr1ngbok
Post #566442 6th Sep 2020 5:46pm
Spr1ngbok
Bump
Post #570305 19th Oct 2020 12:56pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Do these need the rails to fit in to or do they fit in the covered slots in the roof?
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #570487 21st Oct 2020 12:39pm
Spr1ngbok
to be honest I am not sure As far as I am aware they fitted into the slots in the roof and then the screws in the bars tightened with an allen key
David
Post #570492 21st Oct 2020 1:11pm
Spr1ngbok
I could measure length of the end that would go into the slot if helpful
Post #570493 21st Oct 2020 1:20pm
RRDunc
That would be helpful, thanks.
Post #570514 21st Oct 2020 4:08pm
Spr1ngbok
The bit of the bar that goes in slot is 11cm long and c 7mm wide
David
Post #570646 22nd Oct 2020 1:19pm
m@ttsFF
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
These fit in the slots in the roof . One in the middle , one at the front
Lift up the flaps , remove the grub screw , fit bars with M8 x 25 ( I think ) 4.4 AdBlu Tractor
4.2 SC - sold
Post #570672 22nd Oct 2020 6:06pm
RRDunc
So no longitudinal rails needed?
Post #570690 22nd Oct 2020 8:34pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Correct - I had these in my L322 because I didnt want to have to fit roof rails
They are totally removable, lift up the flap, screw them in and you're good
When finished, unscrew and fold down the flaps - you would never know they had been fitted
With the roof rails you have to break the flaps off when you fit them 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #570712 23rd Oct 2020 9:02am
RRDunc
Thanks, Graeme.
Spr1ngbok, you have a pm.
Post #570723 23rd Oct 2020 12:37pm
RRDunc
Thanks, Matt.
Post #570755 23rd Oct 2020 5:57pm
Had a set of these, yes the flaps flip up, if there’s a grub screw take it out.
Originally they came with security torx bolts to hold them on. You literally plonk them on the roof and bolt them in. 5 mins to fit. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #570772 23rd Oct 2020 10:34pm
