Home > Maintenance & Mods (L405) > Water ingress query |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Just in case it is helpful, my 322 (garaged and hence no clogged drains) got water in a rear footwell when the car was caught in a cloudburst for an hour or so. The problem was with the rear door seal. The dealer repositioned it under warranty, and there was no recurrence. Only Range Rovers since 1988 |
8th Sep 2020 12:28pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
Thanks CS - worthy of checking I guess. cheers for the info.
8th Sep 2020 6:07pm |
so ended up changing the shocker, but I've also located the water source I think....its here at the bottom of the door.....so is that the same prob as you had CS? Is it a blockage or not?
16th Sep 2020 12:59am |
With my 322 the leak was coming from the top of the door area, but I have also had a defective seal at the bottom, it seemed to be held on with press studs which were not secure. The leak from the upper seal caused water on the seat cushion, the lower seal would be unlikely to come into the cabin? Only Range Rovers since 1988 |
17th Sep 2020 11:41am |
The thing is, the seals all look good. its obviously coming from the outside so going to test it tomorrow with some ideas the garage gave me for testing.
18th Sep 2020 1:41am |
WaterloggedFFRR Member Since: 22 Feb 2022 Location: Louisiana Posts: 6 |
It's possible it's not the door at all. My 2014 L405 had BOTH sunroof drains rust so badly that the hoses fell
22nd Feb 2022 2:09pm |
