![]() | Home > My Range Rover > First Month of L322 Ownership Has Been Pretty Standard |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3260 ![]() ![]() ![]() |
ref your ABS ecu, have a go yourself. I had all the lights come on and took to to my local LR MD. After 45 mins they came back out and sucking their teeth said "Its gonna need a new ABS ECU - that's £1000 please!" I went out to the car and saw they hadn't even taken off the plug to the ECU (which is the cr@ppiest design and sits upside down so it HOLDS WATER! |
Lowlight Member Since: 16 Aug 2020 Location: North Wales Posts: 5 ![]() ![]() ![]() |
Thanks Dolphinboy, I have cleaned it all up, reattached everything and cleared the codes just to see but I noticed one pin was pretty loose too so I'm not holding out too much hope. It's £155 + VAT for a full refurb so it's not too bad even if it does throw the faults again.
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Good work fella. |
Thought I'd update things a bit, turns out it wasn't the ABS ECU after all. I checked the ABS ring and it had come off the hub so when I did the lower arms I fitted a new one and now have a fault free Range Rover!
