![]() | Home > Maintenance & Mods (L322) > Electrical glitches? |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
H'mm check your drive belts.
just0007 Member Since: 12 Sep 2010 Location: london Posts: 56 ![]() ![]() ![]() |
Thanks the belts look fine, hopefully it will get me back to London tomorrow and then she is booked into the dealer for some attention on Monday. |
The charge light does go out, when I have the transmission fault it states that I have limited gears |
a shot in the dark justin but have you tried disconnecting the battery, seems strange that the faults dis-appear on several turns of the engine.. ... - .- -.
Hi Stan I have just dis connected the battery, how long should I leave it before I power it back up? Thanks to both of you for the advice and guidance. |
half hour should get rid of any juice in the ecu's...fingers crossed. ... - .- -.
Lookers Park Royal Member Since: 30 Apr 2008 Location: London Posts: 463 ![]() |
Quick update, tried dis-connecting the battery problem is still there but now problem is consistent. First attempt to start and nothing the car is dead will not turn over, second attempt to start and car starts with numerous transmission faults, third time lucky car starts and no problems showing. Now back home luckily car at dealer on Monday, they have very kindly organised a new 4.4tdv8 as a loaner and to try and tempt me |
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 ![]() ![]() ![]() |
another shot in the dark but im sure ive read it on this forum, that there is an adjuster on the gear leaver and that it dont quite see the RR in park mode to start it? thus adjusting this sorts out the starting issue.
Thank you for all the advice, just picked it up after a week of being without it. It turned out to be a problem with the ignition. It was not always registering that they key was in the right position. Great to have it back |
