![]() | Home > Wheels & Tyres > L322 Spacers |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Personally, on any vehicle, especially heavy ones the only direction I would point you is away from spacers. 2003 Range Rover Vogue TD6 |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
20mm is not practical for spacers UNLESS you change the wheel studs in the hubs for 20mm longer ones - so that the spacer is truly a spacer, trapped between the wheel & hub & maintaining good thread engagement between the wheel nut & stud.
sumshiftyguy Member Since: 13 Mar 2020 Location: London Posts: 36 ![]() ![]() ![]() |
Thanks for explaining Pawl, very helpful. I am definitely looking at hub centric spacers which is what you're describing so what you're saying does make sense though for previous cars I've fitted 20-25mm spacers. I suppose if it's not a common demand from RR owners, manufacturers wouldn't make them which may be why all I can find are 30mm.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
have a search for ' spacers'.......there are a few threads re this...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
I’m not sure what the guys with the Range Racer have done.
they're not OE wheels so they must have a different offset . ... - .- -.
Yeah, think they might be from an X5. 2011 Range Rover Vogue SE 4.4 TDV8
They look great!
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2709 ![]() ![]() ![]() |
the range racer lads are engineers with JLR, there's a full thread over on pistonheads, worthy of a search there. |
https://www.pistonheads.com/gassing/topic....00&i=0
Excellent, thank you! |
LT Member Since: 13 Mar 2017 Location: South West Posts: 414 ![]() ![]() ![]() |
If you’re on Facebook their page is worth following:
I am following them on FB but the PH thread is a good read so far.
I’d never fit spacers to such a heavy vehicle. In my opinion the potential cons far outweigh the pros (slight visual improvement).
