![]() | Home > Maintenance & Mods (L322) > Rear Brake Disc's |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Right its payday and I've got my bonus so the FFRR is getting a new set of anchors all round. My rears are very shot and i now have a band round the outside of corrosion/scale. its as if the pads aren't touching the full braking surface. Could someone with the 4.4 petrol let me know if this is correct or has some spanner put the wrong pads in?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35728 ![]() ![]() |
done my fronts recently and got them of ebay, discs and mintex pads for around £70 delivered, rear combos are slightly cheaper.. ... - .- -.
Did you use standard discs or up rated? |
just bog standard , and they work really well .. ... - .- -.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Brakes international are pretty good value. My Previous RR's!
these are the fronts ones i got ...
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1760 ![]() ![]() ![]() |
I recently (uprated) the discs and pads all round on my P38 and my CLK and wondered about doing it to the FFRR as well. I just got slotted/drilled/grooved discs all round on the P38 and they work great and look good as well.
slim_sane Member Since: 09 Jan 2011 Location: Kent Posts: 43 ![]() ![]() ![]() |
+1 |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
when mine need replacing i'll be going for Brembo drilled/vented discs and Brembo pads
Rear brakes don't work as hard as the fronts, therefore they tend to build up that rusty ring around the edge. Take the vehicle for a drive at 70mph and when there is nothing behind you slam on the brakes hard, do this a few times and the rust should clear off, it will also deglaze the brakes making them more efficient. |
make sure they are the correct thickness nick, they might be different because of the brembo callipers.. ... - .- -. Y. O. L. O. . |
thanks Stan - have checked and they are specifically for the 4.4 V8 |
