Home > In Car Electronics (L405) > [solved]HUD and nav directions
Ukandrewf
I’m sure my heads up display used to show nav directions. But after a recent service visit and software update it doesn’t any more. Any ideas?
(I’ve checked the hud menu and nav display is ticked)
[solved its working now. Not sure what happened before. Directions only show when approaching a turn etc but I’m sure I tested then last night and they weren’t showing but they are now anyway so will keep a close eye on it in coming days. ] --
On my third Full Fat RR
Post #566993 13th Sep 2020 6:43pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Software bug! I have the non ictpro version in my car and it works perfectly, but I have experienced the ictpro system in other cars and the kind of thing you are experiencing is common. You might also find your proximity cameras drop out too!
Post #567019 14th Sep 2020 2:54pm
Ukandrewf
I have experienced camera and sensors playing up a bit too.
Dealer said at a recent service they had updated the software or something which should have solved the problem with sesnors and cameras which i haven't had a problem with since. A couple of times tyhe sensors did not recognise objects and sometimes reversing the camera would just not appear and the 360 degree sensor image would show instead - wasn't sure if this was some 'clever' deliberate function initially.
I had done the over air software update for the main system but perhaps this stuff is on a different system? dealer appears to imply it is a different system.
this satnav directions in HUD only appeared after the software update but to be fair i rarely used the car satnav - prefering waze in carplay.
Andrew --
Post #567024 14th Sep 2020 3:13pm
