Home > Wheels & Tyres > Wheels/tyres sizes again
RobWheatley
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Hi All
When I bought my 2008 TDV8 it came with RRS wheels (9.5 inch wide style 3 I think) and 275/40/20 tyres (wrong size for mine)
The tyres always looked too small for the arches and the speedo was way over reading (87mph indicated @ 80mph on the sat nav)
MOT was last Saturday and got an advise on one tyre, as they are the wrong size I plan to change all of them, been looking around, would I be right in thinking that 275/45/20's would be a closer match to the original circumference on these rims?
If not what would be?
Thanks for the help.
Rob 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #567022 14th Sep 2020 3:12pm
DrRob
255 50 20 are standard for the L322 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567027 14th Sep 2020 3:21pm
RobWheatley
That's the size I did the calculations on, but from what I have seen/read they won't fit on a 9.5 rim.
New tyres would be within 1% if the standard tyres according to this
Post #567030 14th Sep 2020 3:37pm
RobWheatley
Just found a rim calculator and the 255/50/20 will fit on the 9.5 rims!!
Guess it will be back to standard size then! 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #567034 14th Sep 2020 4:03pm
If you’re keeping the same rims then I’d be going for the wider tyre.
Alternatively you may be able to pick up some cheap wheels that are the correct size.
Or option 3 - find some L405 take offs - they are marginally taller bing a 55 rather than 50 profile, but you can often pick them up for the price of the tyres.
Post #567048 14th Sep 2020 6:46pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I’ve just done this, mine came with 275/40/20’s but I’m not keen so I’ve just picked up a lovely set of standard 20 inch rims and having 255/55/20 Grabbers fitted tomorrow.
Post #567064 14th Sep 2020 8:54pm
Iain24ace
United Kingdom 2007 Range Rover Vogue SE TDV8 Barolo Black
Im currently looking at the same issue and did the size comparisons using an online calculator etc.
275/45/20 give nearly exactly the same side wall thickness and rolling radius as the original 255/50/20 tyre therefore I'll be changing to 4 x 275/45/20 when the time comes.
The ride is also much better on 275/45/20 than 275/40/20 as its nearly an inch difference in side wall height.
Post #567071 14th Sep 2020 9:35pm
