Home > Maintenance & Mods (L405) > Tow Bar Cover?
sgreenham
2015 Range Rover Vogue SE SDV8 Corris Grey
Tow Bar Cover?
I haven't had the car long but I'm assuming I should have a cover under the rear where the detachable tow bar is located?
Post #567041 14th Sep 2020 5:36pm
Looks like an after market tow bar and they’ve removed more than strictly needed.......
You can buy a new cover for not much from eBay and trim as required.
The deployable towbar looks like this, but if you have no tow bar fitted is a full cover.
Depending on how often you use it, you could go with a full cover and just remove the whole thing when towing - 2 min job
Fugly when towing, but neater the rest of the time - like this chap -
Post #567045 14th Sep 2020 6:33pm
Here you go £40 and you can probably find cheaper -
https://www.ebay.co.uk/itm/Range-Rover-L40...Sw3FpdwTHw
Post #567047 14th Sep 2020 6:39pm
sgreenham
That's brilliant. Thank you very much for your help
Post #567054 14th Sep 2020 7:40pm
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
looks like a westfalia towbar. a standard tow cover should fit with no trimming required.
Post #567073 14th Sep 2020 9:55pm
Yes that’s a westfalia same as mine.
You do get a bigger hole if you use the parts recommended by the instructions I refitted one of the old covers The rear part
If I remember correctly and that helped. How mine is set up you don’t have to take anything off to tow. 👍🏻 Can just plug Straight into the plug which is just about hidden.
I have the same plug as the OP. There is nothing that can't be fixed with a hammer😜😜
Post #567074 14th Sep 2020 10:14pm
