Home > Technical (L322) > A couple of gremlins!
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Guys, I have two little gremlins which i'd really like to get fixed before going off on our easter family holiday in the car. First is:
1 Drivers lumbar support inoperative, hums away, but doesn't change support.
2. Rear Screen Ent. drivers side only comes on occasionally, I'm guessing it's a loose connection, but I've had a poke around to no avail
Should I get an auto electrician to fix both things, or a RR specialist?
Thanks. 2012 SDV8 Vogue SE
Post #56714 25th Mar 2011 10:03pm
i believe there is a lumber deflate valve somewhere , sounds like yours has sort of over inflated and got stuck, might be worth perusing rave ...
the rear entertainment problem does sound like a loose connection.. ... - .- -.
Post #56716 25th Mar 2011 10:31pm
