![]() | Home > Maintenance & Mods (L405) > L405 Rear Shock absorber |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2776
The shock has either a badly leaking seal or the reservoir attached near the bottom has come adrift. Either way its a mechanical failure so no real need to replace both sides although you may find a new one firmer than the other side so end-up replacing both.
| M99TYK Member Since: 07 Jun 2019 Location: Tyne and Wear Posts: 50
That’s great Graeme, thanks for the info. |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
As said above its really quite straight forward sir... That all said, i think its worth checking with your warranty co as its a mechanical failure rather than wear & tear... And they are VERY expensive shockers!
| CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779
If its a used car JLR Warranty then its probably only covered under MOT insurance [if its included] so I'd get it into them and have them fail it as part of the MOT and then it will get done under the warranty. all smug in my new plug!
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
Rear seats out, excellent design |
its about 675 a side....... all smug in my new plug!
| Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268
Any chance you can share how to change the rear shocks on the L405? How to remove the rear seats etc. Would be useful. I'm about to take mine off and it would be good to know how you remove them from the car (the bottom is straght forward) but how do you access the top mounting bolts? Do you have any drawings at all that you could maybe share? Many thanks |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
its all in the WM Charles.. |
I dont have access to a workshop manual unfortunately (if thats what WM is?) |
WM download link is in the wiki.. |
Ah ok!! I will download that then |
