Home > Maintenance & Mods (L322) > where does this part go?
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
when I removed the air box this part was lying against the inner wing but i cant work out where it goes?
Post #567299 17th Sep 2020 11:57am
kevinp
PQR 500260 is a drive belt tensioner cap according to the tinternet.
Post #567303 17th Sep 2020 1:50pm
dexion7
Oh, thanks for that Kevinp. just 2 weeks ago i paid a garage to replace alternator and belt so i have to assume that they didn't refit that and let it fall down next to the air box. is it an important part do you know?
Post #567306 17th Sep 2020 3:04pm
kevinp
With it having a part number on it I would presume they made it for a reason. Possibly dust seal type thingy??
Post #567315 17th Sep 2020 4:52pm
t5pete
It will be the cover for a roller bearing on the aux system to stop ingress and to allow access to remove the nut.
Have a look down the front and see if you can see where its missing from.
From a guess ide say its the roller on the drivers side.
Post #567326 17th Sep 2020 7:37pm
Pretty sure it goes on the top pulley. Or tensioner.
Could be this one....
Or this one...
 There is nothing that can't be fixed with a hammer😜😜
Post #567331 17th Sep 2020 7:45pm
