![]() | Home > Technical (L322) > Oil on rear tailgate |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Have you got a dipstick ?
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
Thanks Joe, allegedly no dipstick, it is minor spotting but unusual |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Dreaded oil cooler leak i would expect Rosco... Runs down the rear of the engine then under the car! |
Thanks Craig, as I suspected, can I run if for approx 500 miles until I can get it done?? |
Rosco, you can run them for months like it sir... as long as you keep it topped up then the only damage it’s doing is to your driveway and your nose 🤭 |
Willfen57 Member Since: 13 Sep 2020 Location: Durham Posts: 10 ![]() ![]() |
Sorry to jump on but my 4.4 petrol also shows signs of oil up the tailgate and some.nasty patches on the floor looks like rear of engine above starter motor would mine be the same issue thanks |
No sir, yours would more than likely be the rocker cover gaskets...
Many thanks Craig I'm.alsp having a can bus issue if any one is wise on this |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
I used to have a similar issue with a previous white car but only when towing my caravan. I presumed the bow wave of the caravan some how pushed the exhaust gases forward and onto the tailgate. So I presumed it was 'unburnt ' diesel.
