Home > Technical (L322) > Judder and Reduced performance, 2006 4.2SC |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 |
P0159 / p0160 ? 2006 4.2 SC |
21st Sep 2020 7:26pm |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 |
Yes, I remember the P0160.
21st Sep 2020 8:04pm |
You'd need to carry out electrical tests first to confirm circuit / ecu integrity, as the sensor is not the issue. It is looking like it is just doing its job and reporting no activity being detected.
21st Sep 2020 8:33pm |
This is a very helpful post indeed! These tests is done on the connector to the oxygen sensor and not in the engine bay I guess?
22nd Sep 2020 7:09am |
I need to be sure what bank is bank 2. Can anyone enlighten me? I think RH side is bank 1 but I am not 100% sure. 2006 Supercharged |
22nd Sep 2020 11:36am |
So, I searched a lot, and it seems bank 2 is LEFT. So I tested the reasmost sensor on the left side according to Spud:
22nd Sep 2020 5:13pm |
Hmmm. Firstly you will need to change out that cat if it's rattling when hit with hand. Means it's broken down and most probably is restricting exhaust gases and causing the juddering. You could always do a back pressure test or disconnect like was said before to confirm, but a rattle pretty much confirms a defective cat.
22nd Sep 2020 7:36pm |
I will change the cat. There are some cheap cats on Ebay, are they trash?
22nd Sep 2020 9:35pm |
Yes bank 2 is on the left side. Bank 1 will ALWAYS be the same side as cylinder 1.
22nd Sep 2020 9:54pm |
Part numbers for oem cats.
22nd Sep 2020 9:58pm |
I am Sorry, but how do I measure between pins? If you mean from the pin on the connector under the car and to the pin in the engin bay, how can I do this without using a extra wire? I will look into a OEM cat, no need to be cheap, I have done that mistake before... 2006 Supercharged |
22nd Sep 2020 10:52pm |
My bad, apologies. I use 1.5m test leads for this kind of stuff and made the assumption without giving it thought.
22nd Sep 2020 11:18pm |
N/S is left? We don't use those expressions 2006 Supercharged |
23rd Sep 2020 7:33am |
So, replaced the left cat today. I was surprised that I had to cut the exhaust pipe to fit it! Also, the pipe on the cat should have been reduced to go into the original pipe but was only reduced on one side, so I had to buy a kit to expand the original pipe. It all turned out good in the end.
8th Oct 2020 10:42pm |
