![]() | Home > Maintenance & Mods (L322) > Loose roof gutter trim |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
As far as I know it clips in place, so I'd assume that the clip part has failed.. If that was mine I'd be reaching for my tube of polyurethane adhesive and sticking the leading edge to the windscreen with a small blob..
| phc606 Member Since: 26 Feb 2017 Location: Hants Posts: 16
this small trim shown in the first photo is about 18cm with a rubber end toward the front of the car. the rear of the trim simply pulls forward and slides from the main roof/gutter trim. replacement clips can be found here
| Mcfly309 Member Since: 24 Mar 2016 Location: North Lincolnshire-ish Posts: 76
Very much appreciated, thank you both for your input.
| ptplumber Member Since: 03 Aug 2020 Location: worcestershire Posts: 11
whilst this is an old thread, can anyone point me in the right direction for the clips to replace the front gutter trim, as the link in the original thread no longer works |
| Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342
The clips for most of that channel are these:
| All times are GMT |
