![]() | Home > Maintenance & Mods (L322) > Drop Links |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
You're correct about the rears - definitely a wheel off job.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
Did mine last weekend, much easier with the wheels off. Personally I wouldn’t attempt it with the wheels on.
| JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299
Wheels off it is then, thanks gents.
| gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163
I did my front drop links with the wheels on. Didn't take much more than 15 mins from memory. |
I’m just thinking that there would be less tension on them with the wheels on the ground.
To have no tension on the ARB, you need both front wheels on the ground, or both in the air. |
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
Done them a few times now with both the wheels on and the wheels off. Found wheels on is fine if the nuts are not rusted up. If that nuts are rusted, would suggest wheels off so you can get in with and angle grinder 56 TDV8 Vogue SE
Well after 10 weeks away, I finally got round to it today.
| All times are GMT |
