Home > Maintenance & Mods (L322) > Parking sensors (again..)
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Hi,
I know sensor faults been covered to death but all front and rear sensors click when listened to - so no duff sensors to replace - but still get fault when selecting reverse.
With trailer attached fronts work fine, no fault. Cleaned and checked connectors on pdc unit all lookEd ok.
If all sensors click does this point to ecu trouble or still a possible wiring issue on rear loom?
Had rear bumper off and no obvious chaffing or broken wires.
Ta
Post #568136 27th Sep 2020 2:13pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Have you opened the pdc module & looked inside?
Had issues with mine & it was water damaged inside, possibly condensation as had no other signs of water.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #568202 27th Sep 2020 11:21pm
stenh02
Hi Rob, no not opened it up, but will do. Was your damage repairable/cleanable or did you go for a new module?
Thanks
Post #568205 28th Sep 2020 5:48am
RJH
May have been repairable by someone who understands electrickery, it had clear signs of moisture damage. I just replaced it with a new one.
May not be the same as your issue but worth a check, takes 2 minutes.
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #568206 28th Sep 2020 6:20am
