Home > Technical (L322) > Throttle failed
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
Throttle failed
Hi all, I'd appreciate ideas on this: Driving the other day suddenly 'Engine System Fault' came up, and the engine went to idle. I stopped and restarted, it drove for another while then same again. On the 3rd go the throttle pedal does nothing, except when at full position the engine revs rise a little.
The was was recovered to a mechanic recommended by the AA guy who I've never used before; I wonder if the Collective here might have an idea of what this might be?
Error codes didn't really give me any solid ideas.
Thanks
Andy
(2011 Vogue TDV8)
Post #568347 29th Sep 2020 9:30am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Throttle pedal is effectively a switch , had to replace mine on a earlier one, my foot slipped on the pedal as it was snowy and I broke the pedal assembly, the pedal had come off and i was left with the plastic tube dangling out. It's a simple plug & play unit. Have a look and see if theres breakeage on th throttle. Just bolts in with a serial plug if memory seves correct.
Or wait till Craig is having a cuppa and he might swing by Whistle Whistle
Post #568350 29th Sep 2020 10:34am
kevinp
There are plastic cogs in the throttle body that can strip their teeth. I think a couple of members have had to change theirs.
Post #568352 29th Sep 2020 10:48am
rjff
Andy
If you find the throttle pedal is not at fault, these may help if you have similar symptons to those described.
https://www.fullfatrr.com/forum/topic50004.html
https://www.fullfatrr.com/forum/topic52807.html
Oh, and post up the codes. Cheers
Richard
Gap IIDBT
Post #568362 29th Sep 2020 1:24pm
Alinton
Thanks - the throttle body could be it. I'll post how I get on. The car is away with the mechanic now.
Andy
Post #568364 29th Sep 2020 3:02pm
