![]() | Home > Technical (L322) > Oil leak, oil in coolant, 4.4 TDV8 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
So, I thought I'd pull the pollen filter off and check the back of the engine for leaks as per the advice thread on here, but I didn't quite get that far. I'd noticed an oily/coolant kind of smell when parking the car up, but only having had it for a couple of weeks I've not done enough miles on it to have any idea of how much oil it's using.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
Mine was worse than that when I bought it. Oil cooler replaced and the cooling system flushed about 5 times and it’s still fine nearly 5 years later.
*breathes sigh of relief*
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
oil cooler replacement, coolant system multi-flush and change/new Orings. |
Orings meaning the ones in the turbo pipe, right?
Well if they don’t fix it, and it causes other issues down the line.... how will that sit in their warranty?
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
As has been said, it's a common issue wit the 4.4 TDV8's.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
a joint has been added to your exhaust crossover pipe so it's been cut at some point too
This is positive to hear, thanks! The long thread on here made me think it was common, but of course, not knowing how long it’s been like that prior to me buying it made me worry a bit. Thank you for the feedback, I’m feeling more happy about it this morning ![]() |
Interesting - it’s got a decent amount of service history from a German garage and seems well maintained generally, so this wouldn’t surprise me - the underbody tray is presumably missing too (I didn’t have to remove anything to take the pictures). |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
What’s in the box ?.?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2735 ![]() ![]() |
See if you can get the dealer to fit the Viton O-rings to the oil pipe fitting rather than replace the pipe just to get O-rings that won't last. |
Hmmm, no idea, didn't realise it wasn't standard but you've got me curious now...
I just got back from dropping the car off at the dealer so I can't check, it'll be a mystery for a few days/weeks I guess ![]() I'm guessing maybe it's an aftermarket Tracker, though I admit the very bottom of the car is the least useful place to fit a Tracker and I can't see evidence of any power cable to it... |
Good point, will mention that to them! I'm waiting to see how they diagnose it before saying too much, but it's been left with them this morning so hopefully I'll have some feedback soon ![]() |
