![]() | Home > Technical (L322) > Oil leak, oil in coolant, 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
I just don’t remember seeing one on mine, but it’s a while since I was underneath and I can’t see it mentioned in the WM.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2749 ![]() ![]() |
I should have looked-up the O-ring size before posting - BS611 Viton (2 required). |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
It does look “after market” as it’s much rustier than everything else (despite being coated in 15w30!) And it’s a weird shape being so rectangular and seems to have been welded on - makes me think it’s something that they don’t want to make easy to remove (like a Tracker). I’m wanting the car back even more now, so I can solve the mystery ![]() |
Have actually got some in the post already as I’d read the forum thread and figured they were worth having in the garage ready! ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
i'd be interested to know what that box is as well...
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Tracker or key safe??
I'll give you 3 to 1 on key safe, Tracker is evens ![]()
It's done 83k, so I'm guessing it's probably been through a gasket before looking at the age/mileage people on the main oil cooler leaks thread were mentioning! |
This is the sort of obsessive compulsive behaviour attention to detail I like about this forum ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Found some pics from when mine had a leak. Always good for a chuckle..... 🤣😱
Interesting, you also have that odd little rectangular box, so it's presumably a standard thing! |
Yeah..... amateur |
I’m thinking its a harmonic balancer to take vibration out the subframe. 2011 Range Rover Vogue SE 4.4 TDV8
