![]() | Home > General > Opinion please |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
Evening all
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
I echo David's comments re. the 3.0l engine, however, being closer to retirement than starting my apprenticeship, the smaller engine, on paper, looks to be cheaper (make that less expensive) for RFL, fuel consumption etc, so if I was in the position of a new (to me) car, I would consider these quite important factors. Got - 2017 SDV8 Autobiography in Loire Blue
| Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802
I looked at both a few months ago and went for the 4.4. Partly because it makes a noise that made the switch from an M Sport Exhaust equipped petrol V8 a bit easier but mainly because of the anti-roll system which makes a fairly big difference.
Thanks all
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
I didn’t have the same dilemma.
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351
I decided on the 4.4 also, for much the same reason as NorthernMonkeyJones.
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
There is little evidence - posted on this forum (or that you’ll find on the internet based on lots of research I’ve done) - about the L405s with 3.0 TDv6 engines suffering crankshaft failure.. and for the odd one that did fail, they were replaced under warranty. An important point to note and as with any car, if you follow manufacturer’s service and maintenance schedules including using the recommended grade oils and lubricants, the chances of problems reduce and the chances of manufacturer’s support if problems do arise increase (for cars that don’t have a warranty). The 3.0 diesel in the L405 is an excellent engine. Anyone thinking about it should try one and make their own mind up. A pleasure to own and drive though. Can’t fault it. Some relevant crankshaft threads: https://www.fullfatrr.com/forum/topic45832...crankshaft https://www.fullfatrr.com/forum/topic54027.html Last edited by pld118 on 4th Oct 2020 7:10am. Edited 1 time in total |
I don’t disagree Ryan. The 3.0 is a good engine generally, and having ready the research you’ve done I’m convinced that one wouldn’t spontaneously self destruct as soon at it left the dealers.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
It must be harder to justify with your past history too Ryan... |
It’s all very exciting when you start thinking about swapping car.... but after a month or so of sitting in effectively the same vehicle, I can’t help feeling that you would wonder why you did it! |
